Codec used for capture.
Posted by Paul Doss on May 30, 2006 at 9:11 pmWhat condec does Vegas 4 or 5 use to capture video?
Paul
Donatello replied 20 years, 4 months ago 3 Members · 5 Replies -
Gary Kleiner
May 30, 2006 at 9:16 pmIf you are talking about capturing DV, no codec is used at all. It’s a straight file transfer. The wrapper is AVI Type II.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Paul Doss
May 30, 2006 at 9:33 pmThank you Gary. I downloaded the lastest QT7 player and upgraded to Pro. I have been told that it converts avi to QT better than rendering out of Vegas. The new player will not even recognize my avi files. They are very washed out looking. You can’t even tell what it is. I thought it might be a condec I needed.
Donatello
May 30, 2006 at 10:08 pmwhy do you want QT player to play your AVI’s ?
i assume the avi’s “converted ” to QT that you mean QT streaming files NOT dv.avi files to DV.mov files
Paul Doss
May 30, 2006 at 10:37 pmThis is for someone wanting the avi compressed using QT to DV/DVCPRO – NTSC, 720X480 to be uploaded over the net.
Donatello
May 30, 2006 at 11:50 pmthere has got to be a program that can just rewrite the header on a file so one does not have to render it out from a avi to qt .. i don’t now of any ??
but i do see that if you use DV rack to capture ( on pc) you have a choice for the file to be either avi, mov, canopus and a few others = which means the tape is transferring the SAME data to a pc or mac and the way it ends up QT or avi is ONLY the header that is written with the file …
