Activity Forums Adobe Premiere Pro Codec to MPEG IMX625/50 (50 Mb/s) .Option not appearing from drop down menu??
  • Codec to MPEG IMX625/50 (50 Mb/s) .Option not appearing from drop down menu??
    Posted by Alex Dowie on January 23, 2015 at 3:30 pm
    I currently have a problem, i am trying to export a piece of work for a broadcaster, they require the Codec to be Codec to MPEG IMX625/50 (50 Mb/s). However when i come to select my Quicktime codec it is not appearing fro the dropdown menu, can anybody help me as to where i can find it?
    Many thanks,
    Alex
    Alex Dowie replied 11 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Rob Viscardis
    January 23, 2015 at 6:53 pm
    Hey Alex,
    I’m running CC, and I am finding that codec no problem under quicktime. You’re looking in the video settings section, and not in the “preset” dropdown at the top right?
    Rob
  • Alex Dowie
    January 23, 2015 at 7:26 pm
  • Alex Dowie
    January 23, 2015 at 7:27 pm
  • Rob Viscardis
    January 23, 2015 at 7:28 pm
    Yes it should be in there for sure. Not sure why that has happened. Try sending to the AME queue and see if it shows up there. If not, you may have to reset your codecs somehow.
  • Alex Dowie
    January 23, 2015 at 7:29 pm
    Do you know if there is anyway of downloading the codec from anywhere?
  • Rob Viscardis
    January 23, 2015 at 7:36 pm
    You could try here:
    https://support.apple.com/kb/DL1396
    If you go to Library/Quicktime in finder, you should see the IMXcodec in there, if not you probably need to reinstall. Hopefully the link above will have it.
    RV
  • Alex Dowie
    January 24, 2015 at 2:56 pm
    Yep that worked! thanks so much, i have been stressing out at my computer for about 12 hours over this haha!
