Activity › Forums › Adobe After Effects › Codec Question
  • Codec Question
    Posted by Teto Elsidd on April 18, 2009 at 4:33 pm
    Hi, This might sound like a noobish question, but i think fundamentals are important.
    Shooting in HD. 1920, 1080 and starting out with .mfx.
    What format should i export out mfx on cs3 media encoder or other encoder to a codec that:
    -still retains most of the quality
    -decent file size
    -great color information
    -does’t give mainly Premiere Pro and After Effectsc s3 issues(so a very editble codec)
    Teto~
    Chris Wright replied 17 years, 5 months ago 2 Members · 1 Reply
  • Chris Wright
    April 18, 2009 at 11:32 pm
    If you have the lastest update, adobe should be able to open mfx files. If it can’t for some reason you can go 2 routes.
    1. buy the prospectHD codec that rewraps the data to intraframe without any transcoding loss
    2. use free ffmpeg and transcode to a similar bitrate and chroma codec like dnxhd or dvc pro hd etc.
    FFmpeg can create D-10 MXF files and XDCAM HD 422 files compatible with Avid Media Composer and “import” into bin feature.
    also…
    Before you can copy the files from the fs100, you must go to the “Utilities” page (on the firestore unit) and select “Organize P2”. The fs100 will then correctly organize the footage (along with the audio) into the folders compatible with what Premiere cs3 recognizes as a DVCPROHD P2 file (contents, video, audio, voice, proxy…). After this, just copy the “Contents” folder onto your pc hard drive and import it in premiere.
