Activity Forums Apple Final Cut Pro Legacy codec not found? HELP
  • codec not found? HELP
    Posted by Zach Bauer on August 16, 2007 at 3:11 pm
    I have a G5 with a blackmagic HD card running FCP 6 and i mostly work with 8 bit uncompressed footage. I’ve never had a problem in the past until today when i opened my project and it said “codec not found. You may be using a compression type without the corresponding hardware card.” So i uninstalled and reseeded the blackmagic card. Uninstalled and reinstalled FCP and still said the same thing. The only thing i could think of was quicktime. When i tried opening even an HDV clip the screen was white and it couldn’t play the clip. I unistalled and reinstalled that and still nothing. I was wondering if you could help. Maybe i should download quicktime pro vs. 7.2?. Thank you
    Russell Lasson replied 19 years, 1 month ago 2 Members · 1 Reply
  • Russell Lasson
    August 16, 2007 at 3:31 pm
    Check to see what QT components you have in the Library/QuickTime folder. If you have another system with FCP on it, compare the folders. If you’re missing anything, copy the files that you’re missing over.
    -Russ
