Activity › Forums › Apple Final Cut Pro Legacy › codec not found?
  • codec not found?
    Posted by Chris Johnson on October 29, 2007 at 8:08 pm
    I am using Final cut 6 on a Mac-Intel(the latest) with an AJA Kona LHe capture card. I have a very large project that is done at dv/dvcpro codec, 95% of the raw footage is at dv/dvcpro ntsc codec, there are a few file from After effects that are animation codec. My issue is when I go to render the project it keeps teeling me
    Codec not Found. you may be using a compression type without the corresponfding hardware card. the sequence and the easy setup are both dv codec. the media outputs fine, I just can’t render. any help would be appreciated.
    David Bogie replied 18 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 30, 2007 at 1:41 pm
    Codec not Found. you may be using a compression type without the corresponfding hardware card.< You mean nothing renders or just the Animation stuff form AE doesn't render or your DV stuff doesn't render? Has this ever worked for you or is this your first project? You say it's a large project, how long have you been working on it without any rendering? Must have been frustrating. The presence of the card is the obvious issue. Have patience, some Kona users will chime in eventually but you probably want to talk to the AJA forum people. bogiesan
