Activity Forums Apple Final Cut Pro Legacy “Codec not found.” Error message when attempting to capture.
  • “Codec not found.” Error message when attempting to capture.
    Posted by Lucas Howe on April 3, 2007 at 4:05 am
    I have a PowerMac G5 running an older Final Cut Pro HD (4.5).
    Don’t want to upgrade as I rarely use it.
    Tonight I am attempting to digitize from a DVCPRO SD (not HD) AJ-SD93P.
    It is connected via Firewire.
    I have my device control set on FireWire NTSC (I also experimented switching to
    Basic).
    My capture/input is set to: DV NTSC 48 kHz Anamorphic.
    (I also experiment switching to all of the SD options on the pulldown menu)
    I keep cutting out when I attempt to capture with this message:
    “Codec not found. You may be using a compression type without the corresponding hardware card.”
    I know any and all codecs should be there as I have captured from this format in the past.
    Any ideas? I am going nuts and it is getting late!!
    Please help!
    Thanks in advance.
    Lucas
    Rafael Amador replied 19 years, 5 months ago 3 Members · 2 Replies
  • Michael Gissing
    April 3, 2007 at 4:36 am
    Is the tape DVCPro 25 or DVCPro50? The DV preset you are using is for 25. If the tape is 50 then select the suitable codec.
  • Rafael Amador
    April 3, 2007 at 4:53 am
    Try setting DVCPro NTSC. No DV NTSC. No DVCPro50NTSC.
    Rafael
