Activity Forums Apple Final Cut Pro Legacy codec not found – did i lose my whole sequence???
  • codec not found – did i lose my whole sequence???
    Posted by Olivia Malabuyo on February 6, 2006 at 8:17 am
    gurus – need your help – did i lose the whole SEQUENCE??
    i am using a 1 gig powerbook with FCP3.0 OS X.2.8 – when i tried to add a funny .jpg file to my sequence i got this message
    “codec not found. YOu may be using a compression type without the corresponding hardware card.”
    i have never seen this – i have restarted (saw a ??? for a quick mmoment – everything seems to be ok
    1. do i need to turn my machine in?
    2. any tips to how to re-open that sequence successfully and not have to surrender my whold project????
    thanks for the immediate help!!
    Shane Ross replied 20 years, 7 months ago 2 Members · 5 Replies
  • Shane Ross
    February 6, 2006 at 8:32 am
    #14 Codec not Found
    Shane’s Stock Answer #14:
    If you get a CODEC NOT FOUND missing hardware check ALL your images in Photoshop and make sure there are in a RGB color space NOT CYMK, LAB, OR GREYSCALE
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Olivia Malabuyo
    February 6, 2006 at 6:39 pm
    great – will do Shane
    since i won’t be able to try this for another 6 hours or so…
    question: i did notice that it was only after i added a CMYK image that this happened. will deleting this image from my logging bin SAVE my project? i am nervous that my whole sequence is gone.
    Thanks experts! Olivia
  • Shane Ross
    February 6, 2006 at 8:34 pm
    It will get rid of that message. Your project is fine…it is just that CMYK freaks out FCP.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Olivia Malabuyo
    February 7, 2006 at 2:09 am
    Hi Shane
    here’s my report – i deleted the assumed CMYK file (and others that may cause this issue). I still receive the same message when i try to open the Sequence.
    maybe i am repeating info, but i can’t seem to even get the Sequence to open to show me Missing Media – or which file
    the sequence won’t even open – it “prepares video for viewing” and gets to only about 43% – t hen the message of CODEC not found,etc…….
  • Shane Ross
    February 7, 2006 at 4:30 am
    And did you drop it in the sequence already, because just removing it from the browser doesn’t get rid of it always.
    Try opening earlier versions from the autosave vault. Find one that doesn’t have the picture in the sequence.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
