(!) Codec not found. Compression type w/o Card? HELP!
Okay, this is a real hair puller for me and I hope someone may have the magic answer.A couple of weeks ago I purchased a Sony EX1. I shot some clips in 1080P30.
Okay, that was a test and I moved on to work on the next performance.I created a new project and in EASY SET UP chose DV/NTSC Anamorphic.
I went the the sequence and made sure it was also set up for DV.
I changed scratch disks to the new folders I created for this project.
I digitized several hours worth of footage from a multi camera shoot ALL of it shot on Panny DVX100A set for SQUEEZE – 30P.I started to edit and tried to render out the time line and got the following error message:
_______________________________________________
(!) Codec not found. You may be using a compression
type without the corresponding hardware card.
_______________________________________________HUH? THIS IS A DV PROJECT using DV FOOTAGE. My guess is that FCP has somehow locked into the EX1 format and cannot be switched to anything else.
I have thrown away preferences in library, started new projects, etc. etc. etc.
The same damn message keeps coming up every time I try to render it, export it or print it to video.HELP!!!!!!!!
__________________
Jacques Mersereau
University of Michigan-Video Studio Manager
