Activity › Forums › Apple Final Cut Pro Legacy › Codec not found.
Codec not found.
Posted by Greg Ball on December 5, 2008 at 3:13 amAll of the sudden when trying to render my timeline I’m getting the message Codec not found, you may be using a compression type without corresponding hardware codec.
Everything has been working well until now. It also rendered the first 4 minutes of my sequence with no problem. Any thoughts?
Derek Knight replied 16 years, 9 months ago 6 Members · 13 Replies -
Rafael Amador
December 5, 2008 at 3:21 am -
Shane Ross
December 5, 2008 at 5:59 am#14 Codec not Found
Shane’s Stock Answer #14:
If you get a CODEC NOT FOUND missing hardware check ALL your images in Photoshop and make sure there are in a RGB color space NOT CYMK, LAB, OR GREYSCALE
Shane
Read my blog, Little Frog in High Def -
Jerry Hofmann
December 5, 2008 at 12:18 pmMight post what codec you’re attempting to use? What are your clip’s properties and what are your sequence settings?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Greg Ball
December 5, 2008 at 1:31 pmThis is based on the post below where I’m following Rafael’s and Andrew’s advice on taking an HD EX1 timeline and Create a new sequence, Apple Prorez 422 NTSC open the sequence settings and check the 16:9 anamorphic box. then drop the HD EX-1 timeline into the SD Sequence.
This whole project has been edited rendered and output to DVD. The quality was not great. That’s why I’m trying Rafael’s and Andrew’s advice.
FYI all photos worked fine in the original HD timeline, so I don’t think it’s a photo issue.. The original footage is 1920 X1080i shot at ex1 1080i60.
Right now it’s rendered 10% and seems to be working (knock on wood)
Also it’s saying the estimated time is 3 hours to render the SD sequence which is 17 minutes long. Does this seem realistic?
Greg Ball
December 5, 2008 at 1:43 pmafter 12% completed the same codec not found warning appeared. I had followed Rafael’s advice and saved the project with a new name and restarted.
Rafael Amador
December 5, 2008 at 2:34 pmHi Greg,
3 hours rendering for 17 minutes movie can be normal. Depends of your Mac.
If you see that the render aborts always in the same moment, you my have something in your time-line causing the problem.
Rafael -
Greg Ball
December 5, 2008 at 3:06 pmIt happens in various points in the time line. It renders fine in a DV sequence. But I’m worried about the quality out of a DV sequence to DVD. Thoughts? It seems like the problem is related to Pro res.
Greg Ball
December 5, 2008 at 8:25 pmRafael I really appreciate all of your help. Can you tell me why all of my titles and graphics created in livetype are blown up too large when copying to the SD timeline? Why wouldn’t they have transferred the same way as my video image?
Also the sequence settings I’m using are:
Frame Size 720X486 CCIR 601 NTSC (40:27
Pixel aspect Ratio NTSC-CCIR 601/DV Anamorphic
Field Dominance Lower (even)Compressor: Apple Pro Res 422
Does that all sound right?
Greg Ball
December 6, 2008 at 1:29 amIt turns out that multiple still images are the culprit. However they are all in a RGB color space.
Is there a way to fix this so I don’t have to create moves on each one again? I’d like to just drag the the EX1 sequence to an SD sequence and render. -
Rafael Amador
December 6, 2008 at 2:14 amHi Greg,
If you are coping the graphics from another sequence, you need to “Remove Attributes” from those graphics. Try removing “Basic Motion” and “Distort”.
Why you made your sequence 720×486 instead of 720×480?
Rafael
