Activity Forums Apple Final Cut Pro Legacy Codec not found.
  • Gary Adcock
    December 6, 2008 at 2:55 pm
    [Rafael Amador] “Why you made your sequence 720×486 instead of 720×480?”
    uncompressed is 720x 486…
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Rafael Amador
    December 12, 2008 at 1:20 pm
    Sorry I’m a bit late..
    [gary adcock] “uncompressed is 720x 486…”
    That is just for capture and print to tape presets.
    Uncompress is 720×486 (and Lower-first and NTSC pixels) if you go to print to DigiBeta, Out of that, you can use the size, field order and pixels size that you decide.
    In this case that Greg wants to make a DVD (720×480) from EX-1 footage (1920×1080) it doesn’t makes much sense to work in a 720×486 sequence when you can do it directly in 720×480. One resize is better than two.
    It would be possible even to work in a Uncompress 720×480 “Upper-first” (you skip the “Shift-fields’ to the EX-1 footage). You will get an “Upper-first” QT movie and an “Upper-first” MPG-2 that will works perfect.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Derek Knight
    November 24, 2009 at 6:20 pm
    Thanks Shane! That really helped. One jpeg that was CMYK was screwing everything up.
Page 2 of 2
