Activity › Forums › Adobe After Effects › Codec issues…Too big for DVD
  • Codec issues…Too big for DVD
    Posted by Brian Ew mcnulty on May 6, 2005 at 4:52 pm
    I need to use a suitable codec for video and DVD playback (home DVD player). I’m having problems using any type of codec that doesn’t pixelate the video and jpeg’s/tif’s. I need to stick it onto a DVD and can’t get it small enough. Currently, uncompressed it is 114GB. Could anyone help me, it’s urgent that I get this DVD out today…or it’s my… Thanks.
    Sorry guys, posted to the Communications forum when I wasn’t supposed to…fat fingered it in the wrong place;)
    Brian Ew mcnulty replied 21 years, 5 months ago 2 Members · 4 Replies
  • Steve Roberts
    May 6, 2005 at 5:09 pm
    Eventually, it must be compressed to MPEG-2 if you want DVD playback. You have no choice on the matter.
    In your DVD authoring tool, can you set a low enough data rate to fit the files on the disc?
    Steve
  • Brian Ew mcnulty
    May 6, 2005 at 5:26 pm
    I’m exporting straight from AE. Is this wrong? I was making it an .avi, then using the codecs available. I’m used to just transferring straight to analog tape not DVD’s. I forgot DVD’s can only accept MPEG-2’s. thanks.
  • Steve Roberts
    May 6, 2005 at 5:46 pm
    I render animation codec QT movies out of AE (through the render queue) then drop into Apple’s Compressor for MPEG-2 encoding.
    Rendering MPEG-2 out of AE isn’t wrong, but I don’t know how the quality holds up, or if you get enough choices regarding data rate and quality.
    Sorry I couldn’t be more help …
    Steve
  • Brian Ew mcnulty
    May 6, 2005 at 5:57 pm
    Thank you for your help, I shall try this.
