Activity › Forums › Adobe After Effects › Codec Confliction?
  • Codec Confliction?
    Posted by Tyler Demuth on May 29, 2008 at 5:06 am
    After I installed AE 7 on two computers (both running XP, but otherwise vastly different), both computers act oddly around videos that have been rendered using DivX codecs (in .avi format).
    Even when viewing the files in Windows Explorer, explorer will close itself and I have to restart it with the Task Manager. That, or I can wait some time for it to restart itself. DivX player will still play the videos when I can get to them, but I have to use DivX’s open function to get to the folders they’re contained in, so it seems to be a conflict within explorer?
    What can I do to fix this problem? I have had to move files around using the Command Prompt just to get into folders now because folders containing videos rendered using the DivX codecs, even those downloaded off the internet (not rendered by myself), are closed very quickly due to the video that uses the divx codecs.
    All help is appreciated.
    Thanks in advance 🙂
    Tyler Demuth replied 18 years, 4 months ago 22,730 Members · 2 Replies
  • Tyler Demuth
    May 29, 2008 at 10:53 pm
    I used DivX mainly because I liked the compression rates I could get using it. I have slow internet, and I upload a lot of my stuff to youtube, so I have a real need to keep compression high while maintaining quality. DivX did that very well for me, but if there’s an alternative that can produce video that looks very much the same as it does before being rendered and keeps file sizes to a minimum, I’d like that very much ^^
    Any suggestions to replace my beloved DivX codecs?
  • Tyler Demuth
    May 29, 2008 at 11:05 pm
    Thanks for the suggestion 🙂 I’ll look into buying Quicktime Pro. The replacement is certainly worth $35.
