Activity › Forums › Adobe Photoshop › CMYK in Camera Raw
CMYK in Camera Raw
Posted by Jim Arco on January 26, 2010 at 10:25 pmIs there a way to work with CMYK using camera raw files?
Jim Arco replied 16 years, 8 months ago 2 Members · 2 Replies -
John Mensinger
January 27, 2010 at 9:21 pmIn a sense, that would defeat the purpose of Camera Raw, where the idea is to make global adjustments in the largest available color space.
Perhaps if you frame the question in a more specific context with regard to what you’re attempting to accomplish, there may be other angles.
John M:
All of the vim with none of that annoying vigor. -
Jim Arco
January 29, 2010 at 4:03 amTo answer your question: I have a workflow I use to get good skin tones (from Mark Dubovoy) and I would also like to be able to use it with RAW files.
“…that would defeat the purpose of Camera Raw…” You make a good point, however. I guess I’ll need to convert from RAW to something else before I do final color correction.
