Activity Forums Apple Motion Clouds
  • Clouds
    Posted by Rich E on June 15, 2005 at 6:24 am
    Anyone know how Mekanism did their clouds in the Rock the vote spot up on Apples Motion page? I think they use a PNG of a hand drawn cloud. I have been trying to re-create this (just to see if I could) for two nights now with no luck.
    Rich in Denver
    Rich E replied 21 years, 3 months ago 3 Members · 6 Replies
  • Noah Kadner
    June 15, 2005 at 4:04 pm
    Possibly a pre rendered 2D animation done in another program.
    Noah
  • Doyle Rockwell
    June 15, 2005 at 5:32 pm
    Hey Rich,
    I don’t know what method those clever folks at Mekanism used, but a few particle emitters and some filters can create a similar look. It does get pretty render-intensive, though, so you would probably want to do some pre-rendering. There’s a project called ‘clouds’ that shows it, here: https://homepage.mac.com/specialcase/FileSharing8.html
    Good luck!
  • Rich E
    June 16, 2005 at 4:56 am
    Darn, I was so close! Thanks for tying up the lose end I was missing!
    Rich
  • Rich E
    June 16, 2005 at 5:22 am
    What particle emitter did you copy for it Specialcase?
  • Doyle Rockwell
    June 16, 2005 at 6:30 am
    Hey Rich,
    I didn’t copy any particle emitter. If you download the project and look at the emitter, I just drew a circle shape, made it into particles, set the emitter type to line, then put an attractor behavior on the emitter so that the particles would fall back into the emitter, limiting the cloud’s size. Follow that with the Edge Work filter, dupe it a couple times…and there you have it. It could definitely use some tweaking, but I think it’s in the right direction.
  • Rich E
    June 16, 2005 at 2:44 pm
    Thanks, I actually posted that last one prematurely. I took another look and figured it out. Great job!
