Activity Forums Maxon Cinema 4D Clothilde questions
  • Clothilde questions
    Posted by Christophe Charbonnier on September 26, 2006 at 11:50 am
    Hi everyone,
    2 questions about Clothilde:
    1: I’ve done a simulation using a Clothilde tagged plane with fixed points, falling on a Collision cube.
    When I want to move my plane, it seems like the fixed points won’t move !! And thus my “new” simulation is a mess…
    How do I move my plane (without unsetting the fixed points and then fix them back !) ??
    2: When my Clothed-plane is well set, I want to “bake” the simulation/animation. My goal is to duplicate the object serveral times, and shift them in time.
    I tried to play with cache, but I cannot find any way to shift timing ?? And I guess this is not the good way since if, by mistake, I clear the cache of any of my object, I would not be able to re-simulate since my object would have been moved from its original place.
    How can I “bake” a Clothilde-simulation in order to have “full-control” over time and space of my animation ???
    Thanxs for your help
    Christophe Charbonnier replied 19 years, 11 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    September 28, 2006 at 5:13 am
    1. Use the belt tag instead of fixing points.
    2. Copy your cached cloth object and drop it in a null. Then move the null instead of the cloth object.
  • Christophe Charbonnier
    September 28, 2006 at 6:47 am
    I guess your answer concerns my 1st question. Thanxs
    Do you know how can I “bake” my simulation, like the Resolver tag in Dynamics ???
    My goal is to have control over time; I want to speed-up my plane falling and then slow it down on a certain time. Do you have any clues foe this ???
  • Adam Trachtenberg
    September 28, 2006 at 4:41 pm
    Sorry Christophe, I missed that you wanted to do a time offset. Here’s the trick to baking Cloth animation to keyframes using Mocca>Cappucino set to PLA (only):
    *select your cloth object;
    *activate the axis tool;
    *go into scale mode (use scale tool);
    *click the Cappucino “start realtime” button;
    *click and hold the LMB until the end of the animation (do not drag the mouse during this time!).
    That’s it!
    September 29, 2006 at 12:35 pm
    Hi Adam
    Great ! It works !!!! Thank you for your great help ! I’d have never done it this way…
    Thank you
