Cloth Colliders not working with deformers
I have with cuboid with cloth colliders with a strip of plane attached to it via the cloth belt tag that also has the cloth tag. The cuboid is controlled with a bunch of deformers which was set-up,whenever I run a simulation of deforming the cuboid with the deformers or when I don’t interact with the deformers at all,the strip of plane cloth just passes through it
Is there a way to fix this? I can’t remove the deformers or change the cuboid
