Closed Captioning with Vegas Pro 13
Posted by Greg Buzzell on January 18, 2016 at 4:13 pmWhat other file formats does Vegas output besides MXF that will have Closed Captioning in them. I am able to add the captioning, but I would like to output a different file format other then MXF
Russ Sturgeon replied 10 years, 4 months ago 5 Members · 11 Replies -
John Rofrano
January 18, 2016 at 9:29 pm[Greg Buzzell] “What other file formats does Vegas output besides MXF that will have Closed Captioning in them. I am able to add the captioning, but I would like to output a different file format other then MXF”
You asked this question back in December and the answer hasn’t changed. When you render to XDCAM HD/XDCAM HD422 MXF formats, captioning markers are embedded in the media file. Also when you render to MPEG-2 format, captioning markers are encoded in ATSC format. Those are the only two formats that support embedded closed caption with Vegas Pro.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Greg Buzzell
January 18, 2016 at 9:34 pmThanks. I know I am rehashing this. But the captioning in the MXF file just does not seem right, and does not seem to work. Again this is for broadcast television, so the CC needs to be correct and in the correct line. I will try an MPEG render to see what happens.
Aaron Star
January 18, 2016 at 10:44 pmCC works as the embed is in 608 with up to 4 channels, or the format of your choice. XAVC and HDCAM also support CC, its pretty much the MXF format that supports CC.
You may want to read the CC section in the help file for instruction.
If you have long gaps in your dialog, you may need to insert blank or sound/music descriptions. This will make the dialog CC appear to turn off at the end of a sentence.
To import the CC from a file that already has it embedded, you need to go to File> Import> Closed captioning.
Aaron Star
January 18, 2016 at 11:30 pmForgot to add EIA-608 is the older NTSE standard, while 708 is the newer DTV standard. Vegas only supports 608. For 708 you will need another app that supports 708 embedding. Most TV stations will have a converter for the DTV side so they can supply both.
John Rofrano
January 19, 2016 at 2:08 am[Greg Buzzell] ” But the captioning in the MXF file just does not seem right, and does not seem to work. Again this is for broadcast television, so the CC needs to be correct and in the correct line.”
What problems are you having?
We closed captioned 7 season’s (91 episodes) of Painting & Travel with Roger and Sarah Bansemer for PBS with Vegas Pro and my VASST Caption Assistant plug-in and there are absolutely no problems with the captions in our MXF files.
~jr
Greg Buzzell
January 19, 2016 at 3:20 pmI am receiving a file in MPEG format with a separate SCC file. I can get Vegas to add the SCC file to the time line, and I can see the CC in the preview monitor. I render it out as an MXF file, and using Media Info software, I can see the CC is there. Since I cannot play the MXF file on my computer, I have been reloading it into Vegas, and it shows CC but it does not play out on the Preview monitor. I have also loaded the file into my On Air server, and the server plays the file, but with no CC.
Mike Kujbida
January 19, 2016 at 3:23 pm[Greg Buzzell] “Since I cannot play the MXF file on my computer…”
VLC (it’s a free download) will play MXF files. -
Greg Buzzell
January 19, 2016 at 4:25 pmI have VLC (the latest version), and it will not play MXF files. It crashes VLC.
John Rofrano
January 19, 2016 at 7:15 pm[Greg Buzzell] “I have been reloading it into Vegas, and it shows CC but it does not play out on the Preview monitor.”
That’s because it’s imbedded in the stream. If you want to see them in the preview, you need to use Tools | Scripting | Promote Media Closed Captions to make them caption markers again. Then you will see them in the preview.
There is nothing wrong here. The MXF files contain the captions. Send it off to the broadcast station… you’re done.
~jr
Russ Sturgeon
May 9, 2016 at 11:43 pmI am in a caption dilemma right now. I have been delivering a broadcast project to a distributor that accepts 608 captions for about 2 years now. Last year I started with another broadcaster who said my Vegas files did NOT contain valid 708 caption information. They agreed to take my SCC files from Vegas and fix my MXF stream. This year they told me they could no longer correct this for me. I took my stream to another national network tech center to verify there was a problem. They were able to show me that the MXF file that Vegas 13 pro created DID NOT have valid 708 data in the 708 container. If you open the MXF file created with Vegas 13 in Adobe Premier Pro CC, you will see that the 708 container exists, but it contains random garbage. I am having to have my SCC file converted to a MCC file with a captioning service, and then rendered back together, the MXF Vegas Pro file and the MCC file, with Adobe Premier Pro CC. This is being accepted by my distributor. Sony has not been able to tell me a proceedure that will verify Vegas Pro 13 is creating a valid 708 container with good information in it. The test they described only indicates that something exists, and they can not choose if they are displaying the 608 or 708 captions. I need a better solution.???
