Activity › Forums › Adobe Encore DVD › Closed Captioning Help
  • Closed Captioning Help
    Posted by Larry Zapotocky on November 8, 2008 at 3:55 am
    I have received my .scc files back from a professional captioning company and I import them into Encore CS3 to the video timeline with no errors. When I burn the DVD, I can’t see the CC on any TV.
    I’ve played them on different DVD players and different TV’s but nothing.
    I don’t know if it matters, but the CC is in Spanish.
    I’m on a very tight deadline. If anyone can help please let me know.
    Thank you in advance.
    Larry
    Larry Zapotocky replied 17 years, 10 months ago 2 Members · 4 Replies
  • Joe Bowden
    November 8, 2008 at 4:40 pm
    Have you tried embedding the CC on a different field?
  • Larry Zapotocky
    November 8, 2008 at 7:15 pm
    It only gives me one option: Field 1.
    I can’t find anywhere else to choose another field.
    The .scc files have colons in the timecode (00:00:00:00)and the Encore timeline has semicolons in the time code (00;00;00;00). I changed the .scc original file to semicolons and it still didn’t work.
    I did notice that the .scc file starts @ 00:00:02:09, but my timecode in Encore starts @ 00;00;00;00. Could that be the problem?
    If so, any thoughts?
    Thanks again,
    Larry
  • Joe Bowden
    November 8, 2008 at 10:07 pm
    Hmm, you’re right…CS3 doesn’t offer Field 2. Encore 2.0 does offer both fields for closed captioning.
    Closed captions being in Spanish wouldn’t cause this problem. But the CC timecode beginning at 2:09 might, and the fact that it has colons instead of semi-colons separating hr/min/sec/frame may also be at issue.
    Have you tried replacing timecode colons with semi-colons in the original scc file? Once you’ve done that, also try subtracting 2;09 from all timecodes, and see if that helps.
  • Larry Zapotocky
    November 9, 2008 at 3:21 pm
    I’ve replaced all the colons with semicolons, but I have not tried subtracting 2;09 from all the timecodes.
    I will let you know.
    Larry
