Activity Forums VEGAS Pro Closed Captioning for Windows Media Video
  • Closed Captioning for Windows Media Video
    Posted by Dennis.stewart on June 12, 2006 at 6:01 pm
    Does anyone know how to create a WMV file with closed caption? I’ve tried several ways, and now am blue/red in the face….Help!
    Dennis.stewart replied 20 years, 2 months ago 1 Member · 1 Reply
  • Dennis.stewart
    June 12, 2006 at 6:12 pm
    …i answered my own question… When in doubt.. go to Microsoft….
    SYMPTOMS
    When you play a media clip in Microsoft Windows Media Player 10, the caption bar appears without the caption text. This problem occurs if the media source uses Microsoft Synchronized Accessible Media Interchange (SAMI) closed-caption captioning. The problem also occurs in other Microsoft multimedia programs, such as Microsoft Encarta Encyclopedia.
    Back to the top
    CAUSE
    This problem may occur when you play the media clip from a media source on your local computer.
    Note The media source can be a CD, a hard disk, or a media file that is saved on your local computer.
    Back to the top
    WORKAROUND
    To work around this problem, first check to make sure that the media source contains captions. If captions are present, follow these steps:1. Start Windows Media Player 10.
    2. On the Play menu, point to Captions and Subtitles, and then click On if Available.
    3. Try playing the media clip again.
    4. If the problem still occurs, click Options on the Tools menu.
    5. On the Security tab, click to select the Show local captions when present check box, and then click OK.
