Activity Forums AJA Video Systems closed captioning
  • closed captioning
    Posted by Jeremy Doyle on October 26, 2005 at 7:52 pm
    How do I check to see if I am maintaining captioning on a tape?
    I’m bringing it in through kona, editing and spitting back out to tape but don’t know if I’m losing captioning or not. I guess I’m not really that familiar with captioning at all if someone could explain to me how it works?
    Jeremy
    Jeremy Doyle replied 20 years, 10 months ago 3 Members · 3 Replies
  • David Battistella
    October 26, 2005 at 8:09 pm
    The best way to do it is to play it out of your KOONA 2 to an NTSC monitor that has an option to turn on closed captioning. If the captioning is on the tape then it has also been digitized.
    I am talking SD here.
    On any standard household set. I have a SONY trinitron for this reference, turn on the closed captioning and play the tape or play the media out of the KONA to this monitor and you should see the captioning.
    David
  • Gregg
    October 27, 2005 at 5:27 pm
    Link Electronics makes a decoder PCD-85… A little pricey but it works.
    https://www.linkelectronics.com/
  • Jeremy Doyle
    October 27, 2005 at 6:07 pm
    We ended hooking a beta deck up to a regular old 13 inch tv and it worked just fine. We’re able to do all our checking through that. I haven’t hooked the kona up directly yet, but will probably do that as it would be more convenient.
    Thanks for the suggestions and help.
    Jeremy
