Activity Forums Apple Final Cut Pro Legacy Closed Captioning
  • Closed Captioning
    Posted by Sue Lawson on January 15, 2008 at 8:55 pm
    Hi all.
    Hate to be long-winded, but…
    Client is producing “pre-packaged” programming for television. His agreement with the station(s) is that he will provide them with a Beta SP tape of each program 4 days prior to air. All tapes must be closed captioned.
    After researching (mostly here on the Cow… thanks to all who responded both on- and off-line), it certainly seems most prudent to farm this out.
    So… local place offers me the ability to uploaded either a QT or Window Media File to their FTP site.
    They will export and upload a Closed Caption file (black video with a caption signal — with time code numbers taken from the digital video file) that can be used as an element in FCP. This file, apparently either an .avi or .mov file, is black video with the caption signal embedded at the top of the signal.
    I’m totally unclear on how I would then add this to the original FCP project so the final product (output to BetaSP) has the original audio/video and the Closed Captioning embedded (where… is it line 26?)
    I hoping that one of you guys or gals who have done this before can give me a little guidance.
    Thanks in advance.
    — Sue
    Dual 2.7 GHz PowerPC G5
    2.5 GB DDR SDRAM
    GFX: ATI Radeon 9650
    Mac OS 10.4.11
    Final Cut Studio 2
    FCP 6.0.2 Compressor 3.0.2 Motion 3.0.2 DVDSP 4.2.1
    Brent Robertson replied 17 years, 10 months ago 8 Members · 11 Replies
  • 11 Replies
  • Paul Escandon
    January 15, 2008 at 10:04 pm
    While I’ve never done a workflow like this I’m thinking that you should be able to place the CC’d track in your uppermost video track and crop out everything except the top few lines that contain the CC information. You should be able to do this with the crop parameters in the motion tab in the viewer window.
    Do you have a monitor where you can test if it’s working properly? I have a sony broadcast ref monitor that can read the CC information.. so being able to see that you’re doing it right is probably pretty important.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Sue Lawson
    January 16, 2008 at 3:37 am
    Thanks for the suggestion, but I’m sorry to admit that I’m still confused…
    I’m assuming that because the desired result is “closed” captioning rather than “open” captioning, I really shouldn’t be able to “see” it unless I activate the “closed captioning” option on my TV, right?
    Am I over-thinking this?
    — Sue
    2.5 GB DDR SDRAM
    Mac OS 10.4.11
    Final Cut Studio 2
  • Paul Escandon
    January 16, 2008 at 3:45 am
    Sue,
    I am no CC pro (there’s a whole other department where I work for that) but my understanding is that the closed captioning information is technically “seen” in your final cut because it is indeed visible on the top lines of the screen. The reason you don’t see the closed caption data on screen at home is because it is at the far top of the screen so it is off of the safe region. Needless to say, it actually exists and as far as working in Final Cut I believe you should be able to see it.
    Hope this helps.
  • Adam Tomlinson
    January 16, 2008 at 6:43 pm
    CC is line 21 and it’s encoded allowing the viewer to decode at will. Sue, if I were you I’d seek your answers from the closed captioning house.
    https://en.wikipedia.org/wiki/Closed_captioning
  • Ken Davis
    January 16, 2008 at 7:16 pm
    You just need to add to the track above everything and crop the bottom to 99. ALso make sure timeline specs are 720×486.
    that should do it.
    ken
  • David Bogie
    January 16, 2008 at 8:11 pm
    I post these as a matter of habit to most captioning threads. Valuable information for those who need it. waste of time for those who already know all about this stuff.
    https://www.captionmax.com/faqTechProb.php
    https://www.ccaption.com/nccwork.shtml
    https://www.robson.org/capfaq/
    https://www.channel4.com/corporate/4producers/resources/documents/ForeignLanguageSubtitlingGuidelinesJan06.pdf
    https://www.fcc.gov/cgb/dro/captioning_regs.html
    https://www.fcc.gov/Bureaus/Cable/Orders/1997/fcc97279.txt
    https://www.fcc.gov/cgb/consumerfacts/CC_converters.html
    bogiesan
  • Walter Biscardi
    January 16, 2008 at 8:40 pm
    [Sue Lawson] “I’m totally unclear on how I would then add this to the original FCP project so the final product (output to BetaSP) has the original audio/video and the Closed Captioning embedded (where… is it line 26?)”
    We do this through CaptionMax and they are great and easy.
    You send them a fully Mastered BetaSP.
    They send you back as many copies of the BetaSP you require already CC’d.
    Super simple and they are a great company to deal with. In fact I just got off the phone with them regarding a new project we’re about to start.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Sue Lawson
    January 17, 2008 at 8:08 pm
    Thanks everyone!
    Between your knowledgeable responses… the links and referral that you’ve provided… and the info from my local captioning service, I think I’ve got it now.
    I’m going to run a short test to check my workflow as well as the end result. If I run into problems, I’ll be back with more questions. 😉
    In the meantime, HUGE thanks for all your combined efforts!
    — Sue
    2.5 GB DDR SDRAM
    Mac OS 10.4.11
    Final Cut Studio 2
  • Patricia Demasi
    October 18, 2008 at 10:42 pm
    I know this is a really old post, but I would be very interested in what the final solution to the original post was. I really appreciate it because I have a very similar situation and have been looking for the most cost effective solution for days.
    Thank you very much for your time,
    Patricia
    https://itgwebs.com
  • Sue Lawson
    October 19, 2008 at 3:30 am
    Hi Patricia,
    My client ended up pushing back the project (a series that he’s trying to sell to a network) until next year. (That pesky economy!)
    When we do move forward, however, I’ll be following Walter’s workflow of actually out-sourcing this portion of the job to someone else. I’m essentially a 1-man (okay… in my case, a 1-woman) shop, so… from a time and money standpoint, it makes more sense to have someone else handle this aspect of the project.
    Best of luck, and if you’re able, let us know what solution you employ.
    Cheers!
    — Sue
    4.5 GB DDR SDRAM
    Mac OS 10.4.11
    Final Cut Studio 2
    FCP 6.0.3 Compressor 3.0.3 Soundtrack Pro 2.0.2 Motion 3.0.2 DVDSP 4.2.1
