Activity Forums Adobe After Effects Close-up book animation
  • John Cuevas
    September 30, 2014 at 8:37 pm
    One method, would be to create one giant composition(10240×570.) and fill it full of text, named “Text 1). Create your final comp at normal size and place a texture as the bottom layer. Bring in Text 1 and apply an expression to position, by alt-clicking the position stopwatch:
    seedRandom(index,true);
    startPos = random([0.0,0],[thisComp.width*2,thisComp.height*2,0]);
    This expression will just move your text layers in different places, each layer will be random from the next. Change the layer length to 1 second and add opacity keyframes so the layer fades up, then fades down. Now just duplicate the layer 20 to 30 times and offset each layer, by going to Animation > Keyframe Assistant > Sequence Layers. Offset them by the duration of your dissolve. Make the layers, 3D, add a camera and do a slow move and you are done.
    Check out my example project. 8053_ramdontextfolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Romina Power
    October 4, 2014 at 2:04 pm
    Thank you very much!
    I will try it 🙂
