Activity Forums Maxon Cinema 4D Clones / Instances of Visible Area Lights
  • Clones / Instances of Visible Area Lights
    Posted by Alex Reardon on November 28, 2010 at 3:41 pm
    Hmmmm.
    For some reason, when I clone, duplicate, or instance, a “show in render” area light, the duplicates don’t show in render. Can someone tell me what I’m missing – probably something v simple….
    Thanks in advance.
    Alex Reardon replied 15 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    November 29, 2010 at 4:17 am
    Duplicate with Clone mode and Instances Mode works, Render Instances mode does not.
    Instance works (the Instance Object anyway)
    Tossing the light in an Array works but not if Render Instances is checked in the Array object
    Same thing with a Cloner, if Render Instances is checked, nothing but unchecked all clones are visible but they are not as bright as they should be- that can be fixed by increasing the Visibility Multiplier under the Show In Render checkbox. just multiply 100 times the number of lights (or less than 100 if you don’t want full brightness)
  • Alex Reardon
    November 29, 2010 at 2:50 pm
    Ah HA!
    Thank you so much Mr Jones. You’ve saved me from tearing my hair out! Nice one.
    Love the forum!
