Activity Forums Maxon Cinema 4D Cloner question: repeating base object with changing holes
  • Cloner question: repeating base object with changing holes
    Posted by Daniel Herz on January 15, 2011 at 6:18 am
    I would like to create a cloner with, for example, 10 x 10 copies of the same (non-changing) cube object. And within this cube object is a square hole, i guess cut by boolean operation, that is always of different random size. Is this possible? Basically I need the random effector to effect only one subobject of a cloner and leave the other object untouched.
    To make it more difficult: can the size of the square hole be dependent on a ‘virtual’ image and its brightness level at each corresponding spot, if the cloner were ‘mapped’ to this image. So I would get identical tiles (the cube objects) with holes of differing sizes, where the sizes of the holes recreates an image file. Something similar to a halftone raster. Possible?
    Thanks for comments and advice
    Daniel Herz replied 15 years, 7 months ago 3 Members · 3 Replies
  • André Irniger
    January 15, 2011 at 4:33 pm
    Hello,
    here you got a starting point. You see two cloners, one for the initial Cubes and a second one to create the holes. Now, I controlled the “hole” sizes with a random effector.
    1497_moholes.c4d.zip
    [Daniel Herz] ” So I would get identical tiles (the cube objects) with holes of differing sizes, where the sizes of the holes recreates an image file. Something similar to a halftone raster. Possible?”
    Most probably you can achieve this with the Shader Effector instead of the Random effector.
    Cheers,
    André
  • Brian Jones
    January 15, 2011 at 4:37 pm
    use two cloners, put both into the Boole, that way you can control the size of the clones in the ‘cutter’ cloner with a shader effector
  • Daniel Herz
    January 15, 2011 at 4:50 pm
    great! Thanks.
