Activity › Forums › Maxon Cinema 4D › Cloner Morph Transition
  • Cloner Morph Transition
    Posted by Ashley Glover on July 3, 2022 at 1:03 pm
    I am currently having an issue with the Cloner and Rigid body tag.
    I have two Connect objects which have been keyframed to swap out within the Cloner. However when I press play, the cloned objects don’t transition from one object to the other, just snaps into place. Is there a setting which I am missing?
    William Chidube replied 4 years, 2 months ago 2 Members · 1 Reply
  • William Chidube
    July 13, 2022 at 1:52 pm
    I believe that’s how it has been intended to work. You keyframed the source objects and not any of their transform properties so it makes sense that it will ‘snap’.
