Activity Forums Maxon Cinema 4D Cloner hierarchy + transforming above and below main clone
  • Cloner hierarchy + transforming above and below main clone
    Posted by Ben Waddleton on June 19, 2013 at 9:10 am
    Hi guys – bit of an abstract title but I’ll try and explain..
    I’m cloning a cube that is 200 wide, 200 deep and 40 high, 5 times to create a cube that is 200x200x200
    I’d like to transform the 5 “pieces” so that they explode apart upwards and downwards from the central clone.. at the moment I can only transform them from the BOTTOM clone, so that the pieces are all moving upwards rather than two downwards and two upwards.
    I think it’s something to do with the clone hierarchy.. ie the bottom clone is the “original” clone and everything else is coming after that.
    I hope that makes sense, any help would be great!
    Ben Waddleton replied 13 years, 2 months ago 1 Member · 1 Reply
  • Ben Waddleton
    June 19, 2013 at 9:27 am
    GOT IT!
    used the shader effector with some MIN/MAX to acheive it.
