Activity Forums Maxon Cinema 4D Cloner animates in viewport but not in renderer
  • Cloner animates in viewport but not in renderer
    Posted by Ryan Paterson on May 11, 2011 at 7:42 pm
    So I have this scene file with a cloner using a spline as an object. The spline is being controlled by joints powered by Xpresso. A la this tutorial here
    Anyway the problem is this- the cloner animates perfectly in the viewport but as soon as I send it to the Picture Viewer nothing happens! If anyone has any suggestions please help- I’m getting a little desperate.
    Project-
    2323_tentacletest.c4d.zip
    Ryan Paterson replied 15 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 11, 2011 at 8:15 pm
    I don’t know why that isn’t working, but you can achieve the same effect without all the Xpresso and joints by animating the rotation values in the Cloner’s Object tab. 2324_tentacletest.c4d.zip
  • Ryan Paterson
    May 11, 2011 at 11:19 pm
    Solved! Mograph Cache tag did the trick
