Activity › Forums › Maxon Cinema 4D › Cloned Cloners Color
  • Cloned Cloners Color
    Posted by Darby Edelen on March 2, 2012 at 11:34 pm
    The triple ‘C’ threat!
    I have cloned a cube with the Mograph Color Shader applied. The color is changed using a Random Effector. I want these colors (per cube) to be used when I then clone the cloner, but it appears as though the Color value in the top level cloner’s Transform tab overrides the random color.
    Is there a way around this?
    Darby Edelen
    Darby Edelen replied 14 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    March 3, 2012 at 5:23 am
    when I clone a cloner with a random effector set to change their colours I get cloned colds too. I think it’s working here unless you are trying something different than what I think you mean. Can you post it?
  • Darby Edelen
    March 3, 2012 at 6:31 pm
    Thanks for the answer. I discovered that I had an unnecessary Connect object that was causing the mess. I’ll be more conservative with Connecting things in the future 🙂
    Darby Edelen
