Activity Forums Adobe Photoshop clone and scaling in Photoshop 7 or Photoshop CS2
  • clone and scaling in Photoshop 7 or Photoshop CS2
    Posted by Audrey22 on February 18, 2007 at 11:44 pm
    I would like to sample an area from one image with the clone tool and paint onto another image using the clone tool. However, as I am paint, I would like to scale the pattern so it is smaller in the destination window with the clone tool. Is this possible in either Photoshop 7 or CS2?
    Jonathan Bishop replied 19 years, 6 months ago 2 Members · 1 Reply
  • Jonathan Bishop
    February 19, 2007 at 3:49 am
    Hi audrey22,
    Yes this should be possible however you will have to reduce (scale) the image you are cloning from to make the patern a reduced size in the destination file. This may take a bit of trial and error or you could create a new layer in the destination file to clone onto and then scale that layer to the desired result.
    Hope this helps
