Activity › Forums › Blackmagic Design › Clone an HDCAM tape ??
  • Clone an HDCAM tape ??
    Posted by Steve Cassidy on August 31, 2005 at 7:31 pm
    Assuming that I’m running a Decklink HD Pro (single link) card, Dual 2.7 G5, ProMax Sata Raid, and have one HD deck available
    (HDW-250), is it possible to CLONE a tape…..or will the capture and subsequent output (assuming I’ve done nothing else to the video)
    cause an additional decompress/compress cycle to occur ? (Using HD-SDI both directions of course)
    Seems like I remember from back in my DVCAM days that Final Cut was smart enough to know not to recompress when outputting DV
    back to a deck. I’m unclear as to whether it would be the same with HD when using the HDW-250 and Sony’s HDCAM compression.
    Anybody ???
    thanks,
    Steve Cassidy
    “https://www.cameracopters.com”
    313-920-0660
    Sean Oneil replied 21 years ago 3 Members · 4 Replies
  • Sean Oneil
    September 1, 2005 at 6:51 am
    Sony chooses to only allow the HDCam codec to be transferred natively using tape to tape transfers, or on their own editing system called xpri.
    Sean
  • Steve Cassidy
    September 1, 2005 at 2:21 pm
    Thanks Sean,
    So, I suppose the same would hold true for HD-SR captured and then output back to an SRW-1 with a dual link Blackmagc Card ?
    Steve Cassidy
    313-920-0660
  • Kaspar Kallas
    September 1, 2005 at 4:04 pm
    It is more like coping digi beta – it does employ some compression done in the machine hardware but generation test are OK after 10 or so copies.
    -Kaspar
  • Sean Oneil
    September 1, 2005 at 6:29 pm
    Yes absolutely. It’s a very low amount of compression, so it will be visually lossless after many generations. It’s not like DV where the compression is so high, one generation of re-encoding takes a big hit.
