Clock wipe transition in Vegas Pro 13
Graham Bernard replied 7 years, 2 months ago 2 Members · 36 Replies
Hiran De silva
July 3, 2019 at 6:29 pmThat’s it!
Track Motion is new to me. I’ll look it up. Thanks for your help. -
Hiran De silva
July 3, 2019 at 7:13 pmAha. I got it to work with Track Motion (instead of Pan/Crop).
But there’s one problem with this. Track Motion applies to the whole track – not just the clip. I expect to have several of these ‘call outs’ on one track and they could be anywhere on the canvas. So ideally, I’d want to be applying the transition to a clip, rather than the whole track.
So, I’m still looking.
I still think Pan/Crop should give me what I want (common sense), if only I knew what box I’m ticking that is making the animation centre the centre of the canvas rather than the centre of the image/clip.
Graham Bernard
July 3, 2019 at 7:56 pm[Hiran de SIlva] “But there’s one problem with this. Track Motion applies to the whole track – not just the clip. I expect to have several of these ‘call outs’ on one track and they could be anywhere on the canvas. “
Yes, yes indeed. OK, and this gets back to my idea of rendering an ALPHA channel Callout soooo you could reuse and reuse and so on, placing it where you’d want.
Only use Track Motion to purely Generate your Callout, remove the TM and then move on.
[Hiran de SIlva] “So ideally, I’d want to be applying the transition to a clip, rather than the whole track.”
This way you can Roll yer Own, but also reuse them!
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Hiran De silva
July 3, 2019 at 8:18 pmI’m stuck t understanding what ‘ my idea of rendering an ALPHA channel Callout ‘ means. Can you explain?
At the moment, I draw the circle(s) on my iPad Pro with Apple Pencil, with transparent background and use it on my timeline.
Hiran De silva
July 3, 2019 at 8:22 pmAh, I think I get it.
You mean, instead of having static images of the call outs with Transparent background in my call outs ‘library’ … create a library of animated video clips. Right?
Sorry, my brain wasn’t seeing that …
Good plan!
I’ll do that. -
Graham Bernard
July 3, 2019 at 8:35 pm[Hiran de SIlva] “create a library of animated video clips. Right?”
Correctomundo!
* Grazie
