Activity Forums Adobe After Effects Expressions Clock Hands Rotating but I need a Slider Control or something to control speeds
  • Clock Hands Rotating but I need a Slider Control or something to control speeds
    Posted by Phil Lebeau on January 5, 2012 at 7:42 pm
    I have a basic whimsical clock that has all 3 hands that will rotate from normal speed to as fast as I need it to go.
    I can parent the hands together but what if I wanted to have a slider control that I could adjust that slider and change the speed of all 3 hands… ranging from normal speed up to whatever
    I also need my “hour” hand to go all the way to 12. I can do that too and have the other hands follow
    But a slider to adjust speeds of all 3 hands would be great
    Currently my clock hands are at the 12 o clock mark. But what if I wanted to move my hour hand to start at 3 o clock and have the other hands follow?
    I know the faster I adjust my hour hand, my second hand will be “flying”. At any rate, any help that you might have will be grateful.
    Thank You!
    Phil Lebeau replied 14 years, 8 months ago 3 Members · 6 Replies
  • Dan Ebberts
    January 5, 2012 at 8:39 pm
    Controlling speed in AE is tricky. You’re better off controlling the total degrees rotated. If you keyframe the slider to go from 0 to 360 your hour hand will go from 12 to 12 and you can ease it however you want.
    Dan
  • Phil Lebeau
    January 5, 2012 at 8:54 pm
    Thanks Dan – I dont need to do variable speed – I just need to set it and forget it. I will duplicate the CLOCK comp 3 or 4 times for different speed of clocks.
    Any tips on how I can link the 3 HANDS to one slider???
    Thanks a million!
  • Paul Roper
    January 5, 2012 at 8:56 pm
    What a coincidence, I was just responding to a post by Dan (from 2 years ago) on a very similar topic (rotation speeds and expressions) when I noticed this thread. The post is at:
    https://forums.creativecow.net/thread/227/15551#15559
    and might help you out a bit.
    My response was regarding motion blur using this technique.
  • Dan Ebberts
    January 5, 2012 at 9:31 pm
    You could link the hour hand to the slider and use this for the minute hand:
    thisComp.layer(“hour”).transform.rotation*24
    and this for the second hand:
    thisComp.layer(“minute”).transform.rotation*360
    Dan
  • Paul Roper
    January 5, 2012 at 9:32 pm
    Yes, you CAN link all three hands to the one slider:
    Create a null called controller_null with an angle control on it.
    On your hour hand’s rotation, put:
    thisComp.layer("controller_null").effect("Angle Control")("Angle")
    On your minute hand’s rotation, put:
    thisComp.layer("hour hand 2").transform.rotation*12
    On your second hand’s rotation, put:
    thisComp.layer("minute hand").transform.rotation*60
    Keyframe the angle control from (for example) 0 to 1 to get a 12 hour animation.
    – Paul
  • Phil Lebeau
    January 6, 2012 at 2:28 pm
    Awesome! Thanks everyone for all your help!
