Activity Forums Adobe After Effects Expressions Clock expression Mod
  • Clock expression Mod
    Posted by Harrison Willett on August 18, 2008 at 2:26 pm
    I am using the expression
    rate = 5023.4;
    clockStart = 0;
    function padZero(n){
    if (n < 10) return "0" + n else return "" + n } clockTime = clockStart + rate*(time); but I would like for the decimal to be a constant "x" number of units how do I go about achieving this? Also is it possible to do the same with the front end and add zeros as buffer in the whole digits? for example frame two could be 000167.614 instead of 167.61428094714
    Harrison Willett replied 18 years ago 3 Members · 4 Replies
  • Mike Clasby
    August 18, 2008 at 4:45 pm
  • Harrison Willett
    August 18, 2008 at 8:06 pm
    I agree that they are very versatile but, that is where I got the expression from in the first place. I am still trying to find help to make the units stay in the same place since i could not find the answer in these links.
    Again I want to find a way to make my units stay in the same place so that if I am using 5 units the number 25 would be written 00025
    Understanding how to add units on both ends of the decimal would be helpful.
    If the answer is in these links can someone hold my hand and walk me though this. I am still very confused.
    thanks again
  • Dan Ebberts
    August 18, 2008 at 8:28 pm
    Try this:
    numDigits = 6;
    numDecimals = 3;
    rate = 5023.4;
    clockStart = 0;
    function padZeros(theNumber,numDigits){
    s = theNumber;
    while (s.length < numDigits) s = "0" + s; return s } clockTime = clockStart + rate*(time); clockTime = clockTime.toFixed(numDecimals); splitTime = clockTime.split("."); if (numDecimals > 0){
    padZeros(splitTime[0],numDigits) + “.” + splitTime[1]
    }else{
    Dan
  • Harrison Willett
    August 19, 2008 at 3:02 am
    Dan once again you are amazing and so is your site thank you so much.
