Activity › Forums › Adobe Premiere Pro › clipwrap alternative for windows?
Walter Soyka replied 11 years, 5 months ago 5 Members · 13 Replies
Mark Dagostino
April 2, 2015 at 11:59 amI’ve been transcoding AVCHD to ProRes422 in Prelude and everything works smoothly. I use Prelude because I work with four other editors and we have a media management system that picks up the metadata we input in Prelude so all of us can find assets on our server.
Mark D’Agostino
Video Producer
Creative Media Productions – Exelon
Baltimore, MD
MacPro,2.7 Ghz 12-Core Intel Xeon E5, 64GB 1866 Mhz DDR3 ECC, AMD FirePro D700 6144MB -
Yair Bartal
April 2, 2015 at 12:06 pmBTW I couldn’t find a clear answer as to what I’m missing when I copy an mts file from within the SD card with AVCHD when for example:
1. The length of the shot is less than the file split limit.
2. Audio is a single channel, mono or stereo.Any info?
Walter Soyka
April 7, 2015 at 12:57 pm[Alex Udell] “QT under windows is still essentially a 32 bit pathway. So it’s not the fastest available.”
This is true.
[Alex Udell] “PPro looks at the extension of the file to determine the technology pathway to decode the file.”
This is a good rule of thumb, but it’s also an over-simplification. Pr uses Adobe’s media handling library, MediaCore, to encode/decode MOV files with certain specific, supported codecs. If a codec is not supported by MediaCore, encode/decode falls back to the significantly slower pathway you mentioned: communicating with Apple’s 32-bit QuickTime system via the 32-bit helper process which uses the internal network stack.
[Alex Udell] “And just like that I stick my foot in my mouth…because this one is wrapped in a .MOV… sigh…. well take a look anyway….”
CineForm is one of the codecs directly implemented with high performance in MediaCore. You can read and write CineForm MOVs on Windows without “Adobe QT32 Server.exe” running.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
