Activity Forums Adobe Premiere Pro clipwrap alternative for windows?
  • clipwrap alternative for windows?
    Posted by Yair Bartal on March 30, 2015 at 4:59 pm
    Looking for alternative for clipwrap that works on windows for rewraping AVCHD files.
    I’ve found only transcoding software.
    I’d appreciate any info.
    Walter Soyka replied 11 years, 4 months ago 5 Members · 13 Replies
  • 13 Replies
  • Alex Udell
    March 30, 2015 at 8:13 pm
    Not to get into a long discussion…
    but is the intent to use clip wrap and then to import to PPro?
    thanks…
    Alex
  • Yair Bartal
    March 30, 2015 at 8:32 pm
    Yes it is.
  • Alex Udell
    March 30, 2015 at 10:33 pm
    Wrapping the files, although convenient at the OS level may not provide the best experience for PPro (even if you could find it).
    PPro looks at the extension of the file to determine the technology pathway to decode the file.
    QT under windows is still essentially a 32 bit pathway. So it’s not the fastest available.
    so you may actually be hindering performance and making Premiere force the stream thru a slower pipe.
    so that may be one reason not to do that….
    not trying to confuse ya…but just trying to offer a path that might give you a better result.
    hth,
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Yair Bartal
    March 31, 2015 at 4:07 am
    Thank you Alex for your response, I wasn’t aware of that.
    So if I transcode instead, what would be the recommended container/codec to use for windows?
  • Alex Udell
    March 31, 2015 at 5:36 pm
    Is there a workflow reason you’d transcode?
    or is it that you are looking for a performance benefit?
    Alex Udell
  • Yair Bartal
    March 31, 2015 at 5:50 pm
    Well, we’re members of a communication center sharing a video camera and each member takes the camera for a mission.
    It’s more convenient for us to share the SD card in camera so that everyone just copies his files.
    With AVCHD it’s not recommended to copy the mts files, but to copy the whole card for each member.
    That’s a lot of redundant work and waste of storage.
  • Alex Udell
    March 31, 2015 at 7:03 pm
    OK….
    so you may want to look at going thru Prelude. this will let you browse pick and choose what you want to pull off the card.
    and while a number of codecs would probably work….how about giving the new GoPro Cineform codec a whirl?
    https://www.youtube.com/watch?v=lgPksqpYsXA
    Alex
  • Alex Udell
    March 31, 2015 at 7:05 pm
    And just like that I stick my foot in my mouth…because this one is wrapped in a .MOV…
    sigh….
    well take a look anyway….
    Alex Udell
  • Yair Bartal
    March 31, 2015 at 7:11 pm
    well, I knew about the Prelude option, but tried to find a solution without the need for it.
    Thanks anyway.
  • Steve Brame
    March 31, 2015 at 7:59 pm
    I like the DNxHD OP1a transcode setting in Prelude.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
