Activity Forums Adobe Premiere Pro clips with a wrong refering
  • clips with a wrong refering
    Posted by Abel Rey on May 28, 2010 at 11:21 pm
    once i copied a project to another location in a wrong way. instead of importing i copied. after this i imported into it so i got 2 sources in the project panel and i have clips made good (by import) and other clips made wrong by copy. i tried to refer the bad clips to the source by selecting a clip and “Replace with clip From bin” but i got the all source (from its begining ) and not the edited clip with its right long efects etc. then i tried to do “replace footage” to the source avi that the bad clips are refered to – but it didnt succede because the source is ok. i think i need a way to tell every damage part to refere to the source and keeping its efects. any ideas please?
    Abel Rey replied 16 years, 3 months ago 2 Members · 6 Replies
  • Alex Udell
    May 28, 2010 at 11:40 pm
    Is it possible to make the clips that are wrong in the Project panel “Offline” and then connect them to the right media manually?
    Alex
  • Abel Rey
    May 28, 2010 at 11:47 pm
    the clips are in the timeline-not in the project panel
  • Alex Udell
    May 29, 2010 at 12:47 pm
    I understand.
    But they all refer to the same media files.
    Try this:
    Save as you project so you are working from a safe copy.
    If you go to the timeline and right click on a bad clip, there is an option to reveal the clip source in the project panel.
    In the project panel right click that clip and choose make offline (BUT MAE SURE YOU CHOOSE MEDIA FILES REMAIN ON DISK).
    then, take the offline clip, right click it and choose “Link Media”
    then find the correct media file.
    This should fix it in the project panel and the the timeline.
    Alex
  • Abel Rey
    May 29, 2010 at 5:27 pm
    just one question before i go on
    what do you meen by: BUT MAE SURE YOU CHOOSE MEDIA FILES REMAIN ON DISK
  • Alex Udell
    May 30, 2010 at 12:18 pm
    It is an option that comes up when select “make offline.”
    This means that when you disconnect the media in the project window from the files on the hard drive, the files on the hard drive are not deleted.
    Alex
  • Abel Rey
    June 4, 2010 at 1:14 pm
    thank you for your help
