Activity › Forums › DaVinci Resolve › Clips not in the correct place
  • Clips not in the correct place
    Posted by Hisonni Johnson on June 24, 2012 at 6:07 am
    I have imported an XML into Davinci resolve lite. The clips are importing fairly well but for some reason there are a bunch of clips that are in the wrong place in the timeline. Is there any way to fix this. A better way to import or way to get the correct clip in the place of the incorrect clip. Thanks guys.
    Best wishes
    Hisonni Johnson replied 14 years, 3 months ago 2 Members · 2 Replies
  • Peter Chamberlain
    June 24, 2012 at 6:50 am
    Hi, sounds like you have clips with the same timecode. Or your clips have diff. frame rates. Try flattening the clips to one frame rate or select to use reel number on the settings page.
    Peter
  • Hisonni Johnson
    June 24, 2012 at 2:50 pm
    Thank you soooo much for the tip. Ill give this a try! I had no idea what else to try.
