Activity › Forums › Apple Final Cut Pro Legacy › Clips look good in Quicktime but poor in FCP
Posted by Brendan Pyatt on May 8, 2009 at 4:00 pmI have FCP 6.05 and Quicktime 7.6
I have produced some files from Compressor that look great in QT but in FCP they are poor – the clip is of a boat at sea – the edges of the boat are stepped but the sea looks fine…
Any ideas?
(I am trying, in vain, to convert some HDV60i clips to DV NTSC anamorphic)
Brendan Pyatt replied 17 years, 3 months ago 2 Members · 6 Replies -
Walter Biscardi
May 8, 2009 at 6:36 pmWhat external monitor are you using and how is it connected to the computer.
Don’t tell us you’re using the Canvas screen to judge your image.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Walter Biscardi
May 8, 2009 at 6:42 pmShane Ross also has information in his FAQ.
https://forums.creativecow.net/faq/applefinalcutpro#59
Brendan Pyatt
May 8, 2009 at 7:38 pmThanks for replying.
I am using a Apple Cinema Display hooked up using a Matrox MXO box. I am don’t have alot of experience (obviously!) but I have tried to create a decent setup.
I believe my system is setup correctly as DV clips look fine on it. It’s a converted HDV to SD clip that looks bad…
Walter Biscardi
May 9, 2009 at 10:30 pm[Brendan Pyatt] ” It’s a converted HDV to SD clip that looks bad…”
If you’re making the conversion in FCP, then it will look bad.
Brendan Pyatt
May 9, 2009 at 10:55 pmhi,
The conversion done in FCP looks better than using compressor.
If i convert using compressor and check the result in QT then it looks good but if I then import this clip into FCP it looks bad.
I must be doing something wrong / missing something but I have read and read and been round and round in circles and can’t find a solution.
Brendan Pyatt
May 13, 2009 at 3:24 pmI have confirmed to myself that it is a problem I am having with Compressor. I am sure its something I am doing wrong rather than a bug with compressor but if I take a DV anmorphic clip and run it thru compressor using the same set of settings it looks fine in QT and FCP.
Here are my Compressor settings:
Encoder:
Video:
Compression type: DVCPRO50 – NTSC
Motion: 29.97
Compressor: Best
Scan Mode: Interlaced
Aspect Ratio: 16:9Frame controls:
Frame controls: On
Resize filter: Best
Output fields: Bottom first
Deinterlace: Better
Adaptive details: Unticked
Rate conversion: Best
Set duration: So source frames play at 29.97Geometry:
Frame size: 720×480
Pixel Aspect: NTSC CCIR 601/DV (16:9)Please help! this issue is driving me insane….I really want to use Compressor to convert the clips rather than using the FCP timeline!
