Activity › Forums › Avid Media Composer › clips in timeline to slow motion?
  • clips in timeline to slow motion?
    Posted by Tony Rain on June 9, 2006 at 4:21 pm
    hello,
    is there a way to take some clips that are already in the timeline and make them slow motion? or, do i have to match frame each clip and then figure out the in and out points and then make slo mo and drop each clip back in the timeline? there must be a more effecient way??
    is it okay to ask 2 questions in the same post? if not i will not do so again. when you have a clip in the timeline is there a way to locate it in the composer window with the timeline clips in and out points? i know with matchframe it gives you the in point but is there a way to get the in and out points of a clip thats in the timeline?
    thank you for your time!!!!
    Chaz Shukat replied 20 years, 3 months ago 2 Members · 1 Reply
  • Chaz Shukat
    June 9, 2006 at 8:47 pm
    I’ll answer your second question. If you go under composer settings, edit,and select show phantom marks, it will display the out point but you must still go to it and hit the out point manually. Even if you don’t show phantom marks, you just need to go to the source window and hit go to out and it will take you to it.
    As for your first question, that may be possible by using time warp but I have not mastered that yet so I can’t advise you on that.
