Activity Forums VEGAS Pro Clips in Sony Vegas will not fade with each other?
  • Clips in Sony Vegas will not fade with each other?
    Posted by Anoop Singh on May 6, 2016 at 1:44 pm
    Please forgive me as I am a slight newbie, but I am not able to cross fade selected clips together.
    For example, I can’t seem to make the ending of a clip fade with the beginning of another clip that are on the same timeline. I don’t know why but this never ever happened to me before and I have no idea why I am not able to do this.
    Could someone please kindly help me?
    Thankyou,
    Solid-Snoop.
    Truth is Higher, but Higher is Truthful Living (Guru Nanak Dev Ji)
    Andrew Lenczycki replied 10 years, 4 months ago 3 Members · 2 Replies
  • Mike Kujbida
    May 6, 2016 at 2:30 pm
    Under the Options menu, select Automatic Crossfade.
    The shortcut is Ctrl+Shift+x
    It’s also a toolbar icon.
  • Andrew Lenczycki
    May 6, 2016 at 7:15 pm
    Are you overlapping your two video events? The amount of overlap is the amount of time the two will be transitioning from Event 1 to Event 2.
    Andrew Lenczycki
