Activity › Forums › Adobe Premiere Pro › Clips in premier pro
Posted by Andreea Ris on September 12, 2013 at 12:09 amWhen I bring in my clips in a new project, premier pro creates doubles even triple copies of my clips, Does any one know why..
Andreea
Priyank Kumar replied 12 years, 6 months ago 4 Members · 5 Replies -
Angelo Lorenzo
September 12, 2013 at 5:07 amThis is normal. Each time you copy an asset in your library panel (or import multiple projects that share assets) it becomes it’s own entity that you can remap audio channels, adjust timecode, adjust speed, re-interpret frame rate, and so on without disturbing other instances of that asset across the project.
While, yes, it would be nice to have project manager consolidate these unaltered copies in your bins, it isn’t a feature currently.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Walter Soyka
September 12, 2013 at 5:30 am[Angelo Lorenzo] “This is normal. Each time you copy an asset in your library panel (or import multiple projects that share assets) it becomes it’s own entity that you can remap audio channels, adjust timecode, adjust speed, re-interpret frame rate, and so on without disturbing other instances of that asset across the project.”
If you import sequences from a project (instead of importing the entire project), Premiere Pro will link to existing media instead of creating new master clips, avoiding this duplication.
You can do this via the Import command or via the Media Browser.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Priyank Kumar
March 5, 2014 at 9:20 amI’m not having any luck with this. I’m importing only the sequences NOT the project but it is duplicating the clips. And the clips all reference the exact same location.
Walter Soyka
March 5, 2014 at 11:50 am[Priyank Kumar] “I’m not having any luck with this. I’m importing only the sequences NOT the project but it is duplicating the clips. And the clips all reference the exact same location.”
What version of Pr? I think this should work in at least CS6 and CC.
Walter Soyka
