Activity Forums Square Box CatDV Clips from CatDV not being captured in FCP with proper names
  • Clips from CatDV not being captured in FCP with proper names
    Posted by Allan White on January 12, 2011 at 12:25 am
    Greetings. I’m having a frustrating issue that I could use the community’s insight on. I’m sending clips nicely named from CatDV to FCP. Named like:
    • Rural b-roll, T2 001
    • Rural b-roll, T2 002
    • Rural b-roll, T2 003
    And so on. It gets into FCP, everything looks good, all my metadata is in place. When I go to batch capture in FCP, things go crazy. It doesn’t “fill” the offline movie containers, but instead makes entirely new ones (devoid of metadata), based on the reel name:
    • 10191
    • 10192-1
    • 10193
    And so on. It gives me the proper video regions, but without the metadata that makes it useful. What’s going on here? For some reason, FCP is using the reel info as a base filename. I can’t figure out why it’s ignoring the clip name.
    Any insights? Your wisdom is appreciated.
    – Allan White, Video Producer, Luis Palau Assoc.
    Quad 3Ghz Mac Pro, 10GB RAM, X1900 GPU, XSAN, CatDV Server
    Kevin Duggan replied 15 years, 7 months ago 2 Members · 1 Reply
  • Kevin Duggan
    January 20, 2011 at 6:49 pm
    HI Allan
    make sure you have checked use FCP defaults in the Field Definition Pref . It is possible to map any of CatDv`s fields to the FCP one`s. I suspect you have got them out of whack . This feature is very powerful if you use P2 and other machine named clips.. You can name them in CATDV and then take them over into FCP without renaming the source file … Voila .. man readable clip names
    Hope this helps
    Kevin Duggan
    CatDV/MME
