Activity › Forums › Media 100 › Clips are too dark after digitizing from DV tape
  • Clips are too dark after digitizing from DV tape
    Posted by Martsuk on December 1, 2005 at 11:29 am
    Hi Everybody,
    got a strange one for you…
    I’m using Media 100 7.5.1 lx with a G4 PowerMac running MacOS 9.2.2 connected via FireWire to a Sony DSR-20, and the problem is that when I digitize my DV tapes, the resulting clips are significantly darker (and lacking in both depth and detail) than the original footage (checked on both the Sony DVCam used to record it and a separate Sony DV tape player).
    This appears to be a new problem, perhaps following an office move – and the hardware settings seem to be fine, as do all the other software settings (data rates etc).
    Anyone got any idea what might have happened, and what I need to do to fix it? All suggestions gratefully received!
    All the best,
    Marts.
    Martsuk replied 20 years, 9 months ago 4 Members · 6 Replies
  • Mike Laur
    December 2, 2005 at 6:18 pm
    I’d suggest running s-video out of the DSR-20 into the M100 directly, and not using the firewire route.
    I’m not sure, but with this old version of software and LX, you still may not be able to adjust the input levels within the M-100 input levels control panel, but s-video will at least give you another option.
    ML
  • Jerome Robbins
    December 3, 2005 at 3:54 pm
    Using almost the same set up a couple years ago I noticed the same quality difference between inputing to media 100 via Firewire and S-video. I swapped out every peice of equipment to find the cause. I tried a new DSR-30 deck, Media 100 sent me repalcement card, etc. Bottom line is I use s-video cable for imput.For some unkown reason the firewire washes out the blacks and washes detail.
    Jerome
  • Martsuk
    December 6, 2005 at 5:07 pm
    Hi Dave and Jerome,
    Sorry for the delay in getting back to you (been away for a couple of days).
    Just wanted to say a big “Thank you”, at least I’ve got something else to try!
    Will report back when I’ve had a chance to check out your S-video suggestion.
    All the best,
    Martin.
  • Martsuk
    December 7, 2005 at 10:48 am
    Hi again, Dave and Jerome.
    Okay, so no success so far – images are still dark (doh!).
    Could you please just check over my set-up details?
    Deck to Mac via Firewire
    Deck to Media 100 via S-video
    Hardware set to Video Source In = S-video
    Audio still set to DV
    Devices set to No Machine Control
    Am I missing anything???
    Many thanks (in advance),
    Martin.
  • Kieran Matthew
    December 7, 2005 at 11:33 am
    Couple of quick questions,
    1. Are you seeing this darkening only on DV captured footage, or is this effect visible on all inputs (component, composite, s-video etc) ?
    2. Is playback of material previously captured OK?
    3. Is the material dark on both the external monitor and the Record Window on the computer screen ?
    4. Is your external monitor composite, s, or component ?
    5. Have you tried removing your Breakout Box from the chain and viewing the incoming Firewire input in the Source Window only?
  • Martsuk
    December 11, 2005 at 8:24 pm
    Thanks, Kieran –
    Lots to check out there. Will get back to you as soon as I can…
    Many thanks,
    Martin.
