Activity Forums VEGAS Pro clips are cut off in only in vegas
  • clips are cut off in only in vegas
    Posted by Pieter Samijn on August 23, 2010 at 10:45 pm
    I have a problem with m2t-files in only in vegas. Some of them are cut off and only playing the first 13frames. In Premiere it works fine and also in WMediaplayer of other players (like BS) they play perfect. The files are created with a Firestone on a Canon XL-H1A.
    I have an exemple:
    the file is located here.
    With MediaInfo i have this information:
    Volledige naam : E:\...\20040311-045058F01.m2t
    Formaat : MPEG-TS
    Bestandsgrootte : 28,8 MiB
    Duur : -8s 129ms
    Duration_Start : UTC 2010-08-14 11:16:55
    Duration_End : UTC 2010-08-14 11:17:04
    Totale bitrate : 4 266 Mbps
    Maximale Totale bitrate : 33,0 Mbps
    Datum codering : UTC 2010-08-14 11:16:55
    Video
    Menu-ID : 100 (0x64)
    Formaat : MPEG Video
    Formaatversie : Version 2
    Formaatprofiel : Main@High 1440
    Formaatinstellingen, BVOP : Ja
    Formaatinstellingen, Matrix : Standaard
    Format_Settings_GOP : M=3, N=12
    Duur : 480ms
    Bitrate-modus : Constant
    Nominale bitrate : 25,0 Mbps
    Breedte : 1 440 pixels
    Hoogte : 1 080 pixels
    Beeldverhouding : 16:9
    Framerate : 25,000 fps
    Standaard : Component
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    Scansoort : Interlaced
    Scanvolgorde : Bovenste Veld Eerst
    Bits/(Pixel*Frame) : 0.643
    Audio
    Formaat : MPEG Audio
    Formaatversie : Version 1
    Formaatprofiel : Layer 2
    Bitrate : 384 Kbps
    Kanaal(en) : 2 kanalen
    Samplerate : 48,0 KHz
    Video vertraging : -168ms
    Stroomgrootte : 2,05 ?iB
    Is there a solution for this?
    Greetings
    Pieter
    Pieter Samijn replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
