Activity Forums Adobe Illustrator Clipping mask- strange line?
  • Clipping mask- strange line?
    Posted by Emma Payne on February 2, 2016 at 10:39 pm
    Hi guys, hope I can get a wee bit of help here with you. I’m using clipping masks in Illustrator but the line where I have circled has some strange pixellation issues where the two colours meet- does anyone have an idea how this issue can be fixed and cleaned up?
    Thank you guys!
    Emma Payne replied 10 years, 7 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    February 4, 2016 at 3:36 pm
    Easiest fix I can think of is to include everything inside the mouth including the dark red inside color in the objects being masked by your clipping mask. By this I mean: make a larger area than your clipping mask for that dark red fill and then crop the whole lot (all four objects that make up the mouth) with a single clipping mask to the final mouth shape. That way you won’t have the two separate layers’ antialiasing creating an edge-like artifact.
  • Emma Payne
    February 13, 2016 at 2:17 pm
    Thank you! There’s still a slight problem, but a simple fix as popping a patch of colour between the two.
    Thank you!!!
    Animator, Graphic Designer, Tea maker extraordinare <3
