Activity Forums Adobe Audition Clipboard doesn’t seem to work!
  • Clipboard doesn’t seem to work!
    Posted by Stylz on January 14, 2006 at 10:28 am
    Might be real simple, when I try to copy audio from P.Pro to audition(using copy and paste) I get “No valid audio file in clipboard”. Yes I set audition clipboard to “windows clipboard” still a no go. Any remedies?
    Thanks in advance.
    Stylz replied 20 years, 7 months ago 2 Members · 2 Replies
  • Willie Toth
    January 14, 2006 at 2:30 pm
    You have to EXPORT AUDIO out of Pre pro you can’t just copy and paste it … Once you fix what you want to fix you need to save the changes and then replace the old audio with the corrected clip … The new clip will sync up as long as you keep the same start point as the original clip ………… WILLIE
  • Stylz
    January 15, 2006 at 9:19 am
    wow thats not intergration. Anywho might as well just open audio from video in audition.
