Activity Forums Apple Final Cut Pro Legacy Clip was fine before, now says “Codec could not be opened”??
  • Clip was fine before, now says “Codec could not be opened”??
    Posted by Elysia Cryer on July 28, 2008 at 6:35 pm
    This is a question about Final Cut Express but there’s no forum for that here but hopefully someone will know the answer to this!
    We brought in some .avi clips and they seemed to be fine during the editing process but now some of them say “Codec could not be opened.”
    The only thing we did between the time they were fine and when we got the error msg. was adjust the audio levels by dragging the gray line in the clip in the Timeline. We command-z’d to undo everything but obviously it screwed something up. The clips now appear to be unrendered but when we try to render them a window pops up that says “Codec not found. You may be using a compression type without the corresponding hardware card” and the Canvas has the “Codec could not be opened” message.
    We’re very new to FCE and not sure what to do. Any suggestions would be very much appreciated. Thanks!
    Torbjorn Sassersson replied 16 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    July 28, 2008 at 7:11 pm
    [Elysia Cryer] “We brought in some .avi clips and they seemed to be fine during the editing process but now some of them say “Codec could not be opened.” “
    AVI’s are not supported formats for editing in FCP. They need to be converted to Quicktime before you start editing.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Elysia Cryer
    July 28, 2008 at 7:26 pm
    Thanks for your response. So, there’s nothing I can do to recover what I’ve already done? We spent hours editing and it would be a major drag to have to start over! But at least now we know never to use .avi’s again!
  • Don Greening
    July 29, 2008 at 7:27 pm
    [Elysia Cryer] “So, there’s nothing I can do to recover what I’ve already done?”
    Convert your .avi files to .mov files first. Then make what you’ve already done “offline” in the sequence and then replace with the converted files. You’re edits should remain in place but will now be accessing the converted files.
    – Don
  • Rich Ronald
    October 15, 2008 at 7:48 pm
    I’m having similar issues. I have a .mov clip that views just fine in quick time viewer on my mac and when I import it into FCE, I get a white screen on the left and a red screen on the right with “Code could not be opened.”
    The original clip was edited on another mac with Final Cut Pro. Are there special settings within .mov that need to be set as it is being initially saved/exported by the other editor on the other mac?
  • Tom Wolsky
    October 15, 2008 at 11:23 pm
    What version of FCP was it edited on and exported from? What version are you using?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Rich Ronald
    October 15, 2008 at 11:28 pm
    FCP is version 6 ? FCE is version 4. My mistake in that I couldn’t view this clip in my QT viewer, just the audio could be heard. I have installed ProRes 422 codec and that now works on this file… it’s SD instead of HD but that will work for now.
  • Tom Wolsky
    October 15, 2008 at 11:41 pm
    FCE does not support ProRes and will not work without rendering in the timeline. The ProRes codec is only available with Final Cut Studio. The installation of the codec on another system is wholly illegal and a direct violation of the licensing agreement for use of that software.
    All the best,
    Tom
  • Torbjorn Sassersson
    March 8, 2010 at 9:44 pm
    “Codec could not be opened” – here is one solution
    This problem delayed my project a long time before I sat down to fix it. Finally I found a solution. What happened was that I tried to play the .MOV clip that caused the error message “Codec could not be opened” in QuickTime player. The sound was ok but no video.
    QuickTime than suggested me to download a codec called “XviD_Codec Component 1.0 alpha”. So I downloaded it and followed the installation instructions. I put the codec inside the QuickTime folder in the Library among the other codes. Note! You must not put the codec inside the QuickTime Library folder within the systems folder.
    I restarted QuickTime player and now video was fine. Then I restarted FCP and wonders above all wonders, video was perfect in FCP. No more “Codec could not be opened” when I rendered it.
    a Sasser Media Lab solution… established 7 years before the Sasser Worm 😉
