Activity Forums Adobe Premiere Pro Clip size increases before dissolve transition
  • Clip size increases before dissolve transition
    Posted by Vpsia Bob on August 11, 2005 at 9:33 am
    When I put a dissolve before a title page and at the end of the title page using Adobe Premier, the picture on A increases in size before the dissolve and after the dissolve. Anyone have any idea why this happens and what I can do to fix the problem? I appreciate any help anyone can give me.
    David J replied 21 years, 1 month ago 2 Members · 1 Reply
  • David J
    August 11, 2005 at 4:22 pm
    You don’t give information about your clips, version of Premiere, or hardware/drivers on which to base a detailed answer, however…
    Small size changes have been noted with some capture systems, mostly with pre-Pro versions of Premiere, when a clip is rendered. Unchanged sections of clips are not affected, so the change to/from a rendered section can cause a slight ‘jump’.
    The ‘trick’ to work around this issue, which is generally attributed to the capture card and associated CODECs rather than Premiere, is to apply a ‘do nothing’ effect to the whole clip to mask the size change.
    ‘Do nothing’ effects include Color Balance (HSL) with no change from neutral.
    The cost is that more of the timeline may need rendering, but the benefit is to ‘fix’ the problem you may be describing.
