Activity Forums Apple Final Cut Pro clip shows sound wave, but no sound is played
  • clip shows sound wave, but no sound is played
    Posted by James Wood on May 26, 2015 at 10:04 pm
    I have a clip in which I can see an audio wave, but I can’t hear any sound. The audio wave appears grayed out. My other clips are fine, I can hear them and I see the audio wave more clearly. I’ve attempted to attach an image of the clip from which I can’t get sound, and another where the sound is working.
    Any help greatly appreciated.
    James
    Pablo Vivas replied 6 years, 4 months ago 7 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    May 26, 2015 at 10:20 pm
    Open the timeline idea and click the Roles tab. Make sure the appropriate Roles are turned on (check the box).
  • James Wood
    May 26, 2015 at 10:35 pm
    Hi Jeremy. Thanks for the quick reply. I added the roles column. That particular clip has “Video, Dialogue” in the roles column which appears to be the same for every clip. I went back to the source file and played it. There doesn’t appear to have been any sound recorded. Not sure why the wave appears in FCPX.
    Thanks for the help. I must have screwed up that shot. I can work around it. Just a lot of extra work.
  • Jeremy Garchow
    May 26, 2015 at 10:51 pm
    Can you post a screen grab of the issue?
  • Jeff Kirkland
    May 27, 2015 at 2:38 am
    is James looking at the enhanced waveform? Often you’ll see some ‘ghost’ waveform even if it’s just based on the pre-amp noise from the camera.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • James Wood
    May 27, 2015 at 12:42 pm
    Hi Jeremy. Attached are the images of the clips. The first has just a shadow of a sound wave, the second from which I can hear sound, has a clear image of the sound wave. Perhaps this is what Jeff is referring to, that no sound was actually captured in the first image. I didn’t realize that FCPX would should a shadow wave when no sound was captured.
  • Jeremy Garchow
    May 27, 2015 at 2:54 pm
    Two things,
    1) Thanks for posting the pic. When you said greyed out, I though you meant this:
    2) With the clip selected, open the inspector (command-4) and then click the audio tab. Turn the volume up from minus infinity to 0 and the active waveforms should reappear.
    OK, three things.
    3) Those less opaque waveforms are called reference waveforms. There’s a preference to turn them on or off (Preferences > Editing > Audio, Show reference waveforms). Since the fully opaque or active waveforms are dynamic in fcpx (meaning, the waveforms adjust to volume of filter changes so you can see what’s happening to the audio as you process it) those reference waveforms are handy to show you that there is audio to begin with, and what the audio looks like as a fully expressed waveform.
    Jeremy
  • James Wood
    May 27, 2015 at 6:39 pm
    Hi Jeremy. Thanks for the detailed information. Unfortunately, it’s pretty clear I messed up. The volume was already at 0, not minus infinity, and I turned it up more. There’s simply nothing there. I’ll be okay though. I have a plan to make it work. But again, thanks for taking the time to write the detailed reply.
  • Scott Witthaus
    May 28, 2015 at 1:38 am
    Hi James –
    I had the same thing happen to me. Was banging my head against the wall trying to hear audio, that I could see as a waveform, that never was on the camera file. Irritating FCPX does that. Luckily the crew recorded all audio to an outboard digital recorder. Not fun syncing, but at least it was available. Good luck.
    Scott
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
  • Craig Alan
    May 30, 2015 at 1:42 pm
    Scott. I have a similar issue. Two cam shoot that needs to be synced. Usually this is a piece of cake with multicam in FC. But on one shoot that runs about an hour the on board mike of the second cam was turned off. So there is no reference track. So what methods did you use to sync?
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Deepak Lohia
    November 16, 2018 at 11:13 am
    that could be becz you have solo option on.
    just hit Alt + S on a layer . it should fix the issue.
