Activity › Forums › Apple Final Cut Pro Legacy › Clip problem!
  • Posted by Mike Throck on May 22, 2009 at 6:33 pm
    Having a strange problem, I’ve captured footage from a MiniDV and all of the clips are fine (720×480 DV/NTSC) and display correctly except for the first clip I captured. Final Cut seems to think this clip is 810×480 and I can’t figure out why. I re-captured the same part of the tape and I get the same result. I checked my capture settings and they are all good, and nothing changed in camera from the time I shot that stuff and the rest. Is there a way to make FCP interpret the footage correctly?
    Mike Throck replied 17 years, 4 months ago 2 Members · 2 Replies
  • John Fishback
    May 22, 2009 at 8:56 pm
    Fid you use a fresh tape? It’s possible there’s a snippet of some other format at the head. Are you capturing from the camera or a deck? If you’ve got both, try the other. Can you do a Capture Now?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Mike Throck
    May 22, 2009 at 8:59 pm
    I think it may have been an issue with the deck. Our network uses Sony DSR1500a for capturing and when I tried it on a clamshell it captured fine. Thanks for your help!
